Page 1 of 2
backup time required
Posted: 04 Mar 2014, 20:35
by ik2egl
I noticed that backup creation by menu or closing the program itself requires some time and lock the application.
Also in the opening phase htere is time delay
is there any suggestion or improuvement to reduce this time ?
I am using sqlite and about 68000 qsos logged
Re: backup time required
Posted: 04 Mar 2014, 21:25
That should be OK Don, 68000 is well within the capabilities of SQLite.
Where is the backup file located exactly?
Posted: 04 Mar 2014, 23:16
when you close Log4OM it will:
1) close all existing connections to external softwares
2) saving configuration and form positions
3) making a FULL ADIF backup of the Whole database.
4) clean some rubbish, variables, timers
it should not take more than 4-5 seconds to make an ADIF with 68.000 QSO (it's really faster compared with other softwares i've tried), but you can check this by disabling flag from "auto backup on closing" in Settings 1 screen, and check if time will greatly reduce. If yes, the time is related to backup time.
You can even switch to "manual" backups, pressing the "red cross" button in the top icon bar when you need to backup your data.
It will force a backup/secondary backup
by the way, if i remember correctly, the backup is made 2 times, one for main and one for secondary, for security purposes (if the first one fails i will not copy a missing/corrupted database to the secondary one)
Posted: 05 Mar 2014, 22:32
by ik2egl
Ciao Daniele
Thanks for the info
I will do a check and will have a look to the log too where I should see some elapsed time
Posted: 13 Mar 2014, 11:08
by ik2egl
I have disabled the automatic backup on closure and now closing is faster as global result
let say that I have, on a XP pc witj 3 gb and a low performance HDD, the ratio i 1 (no backup) to 5 (with backup) [5 secs to 25 secs]
log contains 68000 records
tnx
Posted: 13 Mar 2014, 14:54
20 seconds for 65000 QSO is REALLY slow... can you try making backup into an USB drive to see performances?
Posted: 13 Mar 2014, 18:36
by ik2egl
with a usb key as bakup the time delay is really worst (something less then 3 times more)
consider that the adif file created occupies 52.890 K, (so it is not so small).
are you sure that a zip file of the .SQLITE file could not be a posssible alternative stategy for backup ?
Posted: 13 Mar 2014, 19:56
52 megabytes??????
Posted: 13 Mar 2014, 21:12
by ik2egl
yes,
and the .SQLlite file is 24 mega for 68000 qsos
Posted: 14 Mar 2014, 08:36
there is something wrong in that...
can you zip me your ADIF and mail to iw3hmh @ (this website)?
