Re: SET UP FOR SWL
Posted: 25 Apr 2020, 05:43
Log4OM doesn't support SWL logging because it requires a completely different logic and framework.
All statistics and maps are based on the concept that the user station is the pivotal center of the system, while in a SWL situation you're listening two different operators potentially far away from your location. It will also require two different lookups for the stations, and that is not supported.
A valid call sign is required because the software automatically derives much of the operating information from the call.
There are specific SWL programs like DXtreme and EsiSWL etc which might work for you
