Import csv file
VA3XOV
Import csv file
Post by VA3XOV »
Is it possible to Import a csv file? I checked the help file, but could not see it, or over-looked it. Thanks
NN7D
Re: Import csv file
Post by NN7D »
Hello ?,
No, it is not possible, as far as I know. Its not listed in the File menu.
Just curious, where is this .cvs file coming from?
Doug
W7DRM
Re: Import csv file
VA3XOV wrote: 24 Apr 2020, 00:29 Is it possible to Import a csv file? I checked the help file, but could not see it, or over-looked it. Thanks
Yes in the awards statistics also SOTA and IOTA awards and the award manager when constructing or updating an award.
What is your reason for wanting to import csv files?
VA3XOV
Re: Import csv file
Post by VA3XOV »
Hi Doug and Terry,
Thanks for the advise. I exported some contacts to make some changes, and I thought an excel file would be easier to make the changes with. I made the changes and would like to import them back. I will try and see if it works. Thanks
Re: Import csv file
VA3XOV wrote: 24 Apr 2020, 20:34 Hi Doug and Terry,
That wont work you need to convert the csv file to an ADIF file using an on line converter and then import the ADIF file
