how to receive your Lotw qls with Log4OM.
I get this error message every time I download
Warning:Return HTML FILE i, LOTW dowload.
Please check file saved in c:\Users\Bernard\AppData\LogOM\20200422133602_LOTW_INCOMING_FILE.ADI
I have the latest version of TQSL and my version of Log4OM is 1.41.0.0
I've looked at several tutorials, no solution found.
Yet when I go to QSL tools/Qsl management/Lotw I send my qso to Lotw.
Thank you for your help, I look forward to reading you.
F1UFX Bernard
Translated with www.DeepL.com/Translator (free version)
Dowload qsl Lotw
Re: Dowload qsl Lotw
Did you look at the file it refers to saved in c:\Users\Bernard\AppData\LogOM\20200422133602_LOTW_INCOMING_FILE.ADI
This is a message from LOTW that explains the problem!
Moved to the correct V1 section.
HelloG4POP wrote: 25 Apr 2020, 10:32 Did you look at the file it refers to saved in c:\Users\Bernard\AppData\LogOM\20200422133602_LOTW_INCOMING_FILE.ADI
can you give me directions to the solution from Lotw.
Post this file c:\Users\Bernard\AppData\LogOM\20200422133602_LOTW_INCOMING_FILE.ADI to this forum
Someone has a solution.
Thank you
Thank you
We cant find a solution unless you actually post that file to the forum or open it and paste the contents into this threadbernard wrote: 28 Apr 2020, 07:37 c:\Users\Bernard\AppData\LogOM\20200422133602_LOTW_INCOMING_FILE.ADI
Thank you
Your other choice is to send us a support request from the help menu. DO NOT POST THAT FILE TO THE FORUM YOU MUST SEND IT TO US BY EMAIL ONLY
