v2 log4om- new JTDX and JTalert
Posted: 25 Apr 2020, 12:06
by nd1x
The newest update for Log4om works. Nice map feature etc. new version JTDX installed and JTAlert. Here is the problem. Using Omni Rig (Ft 3000) same parameters for all 3 programs. I can hear FT 8 through my radio speaker. Using Codec. JTDX is scrolling calls etc. Now I engage transmit and the radio is transmitting but no power output? I check the radio on CW and SSB and full 100 watts. The power bar in JTDX is all the way up. The radio is in Data/USB. After a transmit the radio defaults back to USB?
I did reset the radio and even check com ports, mine are Com 3 and Com 4 enhanced and that is what the radio is connected too. Any help is much appreciated. Also I did check in JTDX, that I did receive a green connect and I also did the tune function and can hear it through my monitor on the radio. Sorry for the long explanation
John
ND1X
Re: v2 log4om- new JTDX and JTalert
Posted: 25 Apr 2020, 12:22
by DF5WW
Hi John,
if the radio goes to transmit if you made a transmission in JTDX or using the Tune button
in JTDX all is fine. What you describe looks like a problem with your soundcard settings.
If JTDX don´t receive audio from your soundcard it opens PTT line but without audio you
have no output.
Maybe wrong soundcard settings in JTDX or the power slider is down in JTDX main window
or in your pc the audio is muted or has a to low level.
That´s what you have to check.
By the way .... please tell also what your radio is and what´s your Windows.
