adding 60M to DXCC
Posted: 03 May 2020, 07:51
by ES2MC
Can somebody suggest, what is the right procedure of adding 60m to the DXCC statistics? As if I can do it by editing the DXCC tab from Award manager and then it appears to the award statistics also, but the number of worked and confirmed countries is by far not the actual one. If I am manually counting my 60m countries (suggestion - the statistics list could have a total count at the bottom, currently this is very inconvenient!), then e.g. getting 86 confirmed. But the award statistics just shows 44 wrked and 36 cnfmed. What might be the issue? Also - there are no cw qso-s shown at all, i.e. just digi only (true, most of my countries there are worked in FT8), though I have made possibly also 30...40 countries on cw also (but not probably very many unique ones in cw, they are also made in FT8 now). So, more than half are missing compared to the Statistics list...
For additional info - migrated from Log4OM v1 to v2 - and my FT8 are done with JTDX and qso-s getting into the log via GridTracker (earlier with JTAlert). This works properly.
Gratefully,
Arvo, ES2MC
Re: adding 60M to DXCC
Posted: 03 May 2020, 21:43
by KD0ZV
Arvo,
Even though its not a DXCC band you can easily add 60 meters using the award manager.
Posted: 08 May 2020, 06:10
by ES2MC
Hi Rich,
Well, I have done this, but the problem is, that the Award statistics under DXCC is NOT CORRECT after that! If you read my message thoroughly, then you should get the "point", hi! I have more than half of the countries missing that I have actually worked and confirmed and that I can see under the Statistics tab. Therefore, it must be either some kind of database issue (migrating from the older version of Log4 to the new one?) or, some other, set-up problem of the DXCC award in the A-manager, but I can not currently see what I have done wrong… On the other hand - my other bands' DXCC award statistics seem to be correct, i.e. they match with the Statistics tab's countries count. Which, as if excludes the data-base issue (?).
Any further suggestions from anybody?
73, Arvo
Posted: 08 May 2020, 07:29
ES2MC wrote: 08 May 2020, 06:10 Hi Rich,
73, Arvo
When you imported the Log4OM V1 database which ADIF format was it and did you choose the 'Apply quality checks' option in the V2 ADIF import ADIF window?
And you should use the 'Statistics tab in the award screen to view the countries worked
The count is Countries not QSO's worked because you can work China 100 times but it still only counts as one country in the awards
Posted: 08 Jun 2020, 20:14
by ES2MC
Haven't been here for a while… Now upgraded the version to 2.7.0.0. - but the issue still remains… Of course I did the quality check for the database, at least I did all that seemed to be "normal" at that time. And I assume that if I had not done it properly, all the other bands would have also been with wrong numbers - would that be logical? (why only 60m?)
What I am trying to say is, that there are (as you know) 2 places where you can see the countries that are worked/confirmed - the Statistics tab has them as a list (unfortunately with no total number counted, you have to count them manually) - in that tab ALL the actual statistics seem to be ok, number of green fields (confirmed/validated) close to 90 entities (manually counted from the screen). If the database had been wrong, then I assume this data would also have been, right? But this seems to be correct! And I really have those countries wrkd/cmfed, can see it from the QSO data!
But now, if you go to the Award Status tab and choose DXCC countries' count, I do get a totally another number of countries worked/confirmed compared to what I just have counted (manually) from the Statistics tab! About 2 times less! I have tried to explain that all the time, but seems that "have failed to explain my point", hi! Is it because how I am defining the DXCC on 60m? (just ticking the 60m box in the bands' list?) Or something else?
Can I somehow read the WHOLE database into the V2 again? But how to avoid double data? What is the right procedure for it? I might try to reload the whole base once again "as clean"... (but then again - why just 60m, why other bands are ok?)
Gratefully,
Arvo, ES2MC
Posted: 08 Jun 2020, 20:50
by KD0ZV
Arvo,
Couple things. Go into Award manager again and add your 60 meters (again) and go to the confirmation tab and set the two sections the way you want them.
Once you are done with that and its saved go back to your award stats and click the maintenance tab. Rescan the award references.
See if that does anything. Right now these upgrades are wiping out the award settings. Until Lele fixes it we are going have to deal resetting that each time.
