Hi guys,
I play JT65 mode, I work now with JT65HF-Comfort + JTAlert + HRDeluxe (Simon version).
Now I would to change the logging software to Log4OM and I wish will work all togheter.
Can someone help me to work all togheter?
My Windows is W7 64bit, my radio is FT897, my separate sound card is one cheap USB stick, my pc interface is USB made by DK4MX.
Thanks, Camillo iz6gvc
Someone can help me?: Log4OM + JT65HF-Comfort + JTAlert
Re: Someone can help me?: Log4OM + JT65HF-Comfort + JTAlert
Ciao Camillo, we have discussed a lot about this in the forum.
Argument is covered there: http://www.pisto.it/forum/viewtopic.php ... jt65#p2765
there: http://www.pisto.it/forum/viewtopic.php ... =jt65#p858
and there is a chapter on the manual (page 150) that covers this implementation.
Basically you need to start log4om external services and follow the instructions (step by step, it's very easy and plenty of descriptive images)
The manual covers the whole process in all softwares.
You can download it here: http://www.pisto.it/LogOm/Log4OM_enu.pdf
Ask for help if you're in troubles
Hi Daniele, how are you?
I tried with this two "guides" but I've some litle trouble.
1) - I start for first JT65HF-Comfort 3.8 with Admin Privileges, Omnirig selected for CAT; but the QRG changes is very slow and the decode (after the 50") is show about a the 53/55 seconds.
The remaining time for Call selecting is very short.
2) - For second I start JTAlert also with Admin Privileges, and work perfectly (without Admin Privileges JTAlert not work B4 and call info); integration with Log4OM is OK via port 2236.
3) - For last start Log4OM also with Privileges, without CAT controll, but some times the setting page freeze and I made Ctrl+Alt+Canc!
Can I help with some screeshoot?
73s, Camillo iz6gvc
73s, Camillo iz6gvc
73s, Camillo
I'm not expert about those modes, never used, but this setup is very popular and probably there is someone there in the forum that could help you better than me with comfort. Anyway screen shot help.
About point 3, it's Log4OM that freezes? If yes I wish to investigate more on that. Is that situation reproducible? Can you freeze it again?
Daniele
Daniele
Hi Daniele and guys, some screen.
- CAT + PTT
- JT65HF-Comfort Rig Control+PTT.jpg (84.18 KiB) Viewed 10936 times
- Logging
- JT65HF-Comfort Colours+Log.jpg (152.15 KiB) Viewed 10936 times
- Main screen
- JT65HF-Comfort.jpg (235.71 KiB) Viewed 10936 times
73s, Camillo
Many sreenshoots.
- JTAlert Logging
- JTAlert Logging.jpg (193.42 KiB) Viewed 10936 times
- JTAlert ERROR
- JTAlert error on opening.jpg (76.06 KiB) Viewed 10936 times
- Diagnostics
- JT65HF-Comfort Diagnostics.jpg (88.93 KiB) Viewed 10936 times
73s, Camillo
Other many many.
- Log4OM Communicator
- Log4OM Communicator.jpg (66.85 KiB) Viewed 10936 times
- Log4OM
- Log4OM.jpg (248.96 KiB) Viewed 10936 times
- JTAlert Logging with Log4OM
- JTAlert Logging Log4OM.jpg (169.02 KiB) Viewed 10936 times
73s, Camillo
Many many many.
End!
End!
- Log4OM Settings and Freezing
- Log4OM Settings Freezing.jpg (233.46 KiB) Viewed 10936 times
- Log4OM Communicator FLDigi Settings
- Log4OM Communicator FLDigi Settings.jpg (46.15 KiB) Viewed 10936 times
- Log4OM Communicator Inbound Settings
- Log4OM Communicator Inbound Settings.jpg (35.98 KiB) Viewed 10936 times
73s, Camillo
In Log4OM communicator you do not want to point to the JT65 path in
Temporary ADIF file polling
or
ADIF file polling
Please leave them blank
Because that is not how the contact is logged from JTAlert!
As the JT65 instructions say's it sends the contact to the Log4OM SQLite file
You must enter the path to your Log4OM SQLite file into JTAlert something like the screen shot below
Also in JTalert ensure that the Server IP address and UDP Port as as shown in my screenshot, unless you are using it across a network.
I don't use JT65 but I set up JTAlert to check everything works and it is working 100% OK with Log4OM so the issue is in the set up at your end.
or
ADIF file polling
- Screenshot 2014-03-19 09.45.05.png (76.8 KiB) Viewed 10910 times
I need to talk with JT-ALERT author about the "log4om bug" he stated in his form...
