If I imported my QSO's from version 1.40.0.0 by help adif version 3 it would be ok. If I imported a new QSO's by adif from Outd log so there aren't correct information in the table - Edit QSO My QTH.
There is missing Station country, My name, My address etc. I have all information in my setting. Why aren't there these information after import adif? Do I make something wrong?
Thanks a lot.
Table Edit QSO, My QTH after import adif
- Novice Class
- Import adif version 3 from version 1.40.0.0.JPG (54.11 KiB) Viewed 2112 times
- after import adif from Outd log.JPG (53.07 KiB) Viewed 2112 times
- My setting.JPG (103.56 KiB) Viewed 2112 times
73 de Jarda OK1JHR
Re: Table Edit QSO, My QTH after import adif
Log4OM can't assume you are in same location or country as when you made the qso's. You need to use QSL Manager and do bulk updates of My Country where needed.
Doug
W7DRM
Doug
W7DRM
- Novice Class
Thanks a lot for your explanation Doug.
73 de Jarda OK1JHR
