Eqsl SAT MODE
Posted: 16 May 2020, 10:58
by EA4GSX
Hi guys
I am having problems with the QSO´s uploaded to Eqsl, friends start sending me emails that SAT mode does not appear in Eqsl logs. Does anyone know to tell me what is due ?. When registering the qso I activate the SAT mode box so I do not understand why this is happening.
Thanks in advance 73
Re: Eqsl SAT MODE
Posted: 16 May 2020, 11:31
by DF5WW
Hello OM (A name as signature would be fine),
the problem is that eQSL using the declaration instead of the enumeration for SAT mode.
Prop_Mode for Satellite has "SAT" as ADIF 3 enumeration but eQSL is using the "declaration"
for SAT which is Satellite. If you use the LotW too you will see that uploads for satellite contacts
are all fine. Something is wrong elswhere on eQSL. We using strictly ADIF 3 so no changes
possible from Log4OM side.
I have asked in the eQSL support forum for this but no answere from any team member of
eQSL.
Re: Eqsl SAT MODE
Posted: 16 May 2020, 17:44
by EA4GSX
Hi Juergen
Many thanks for information. I hope that the problem is solved soon and that you have help from Eqsl.
73 de Miguel
Re: Eqsl SAT MODE
Posted: 16 May 2020, 18:49
by nn3rp
I am having the exact same issue. eQSL website does not show the QSOs as Satellite. I have created a new post to my concern today here. I am new to this Log40M world. I am using the latest Log40M software. I configured it per the user guide and even watched the latest videos by Terry / G4POP which are excellent. I am also noticing that LotW website, although Log40M uploads without any errors, the QSOs are not found!
QSOs uploaded automatically by Log40M:
I've just uploaded some QSOs to eQSL and LotW using TQSL softare. Notice the Sat entry:
This is how the main Log40M GUI looks when entering a call sign;
Luckly, I only have about 15 entries using Log40M. Until I can see a fix, I can't continue to use it since the other person is expecting a confirmation of the QSO
Re: Eqsl SAT MODE
Posted: 17 May 2020, 15:32
by LU4FTA
Hello, a suggestion would be that you could select the unloaded qsos and export them to an Adif file and then be able to upload them to Eqsl. Confirmation information would be updated.
Thank you and 73.
Felipe LU4FTA. ;)
Re: Eqsl SAT MODE
Posted: 17 May 2020, 20:15
by nn3rp
Saludos, Felipe. Thanks for the suggestion. Yes, you could do that but it defeats the purpose of automatic (don't bother) uploads. I am sure that Log40M gurus will make it work soon. We all appreciate they support for this marvelous software and I hope that we all agree and $upport them.
I've been testing the manual upload by exporting the ADIF with only the needed entries. These are the entries that make the eQSL website to show corrent qso for me, YMMV:
# Log4OM 2 by IW3HMH version 2.6.1.0
# http://www.log4om.com
# created: Sunday, May 17, 2020
<ADIF_VERS:5>3.1.0 <PROGRAMID:7>Log4OM2 <PROGRAMVERSION:7>2.6.1.0 <eoh>
<BAND:4>70cm
<CALL:6>KK4YEL
<MODE:3>SSB
<QSO_DATE:8>
20200517
<SAT_MODE:2>VU
<SAT_NAME:5>RS-44
<TIME_ON:6>005245
<PROP_MODE:3>SAT
<APP_L4ONG_SATELLITE_QSO:1>Y
<EOR>
Re: Eqsl SAT MODE
Posted: 18 May 2020, 03:04
by nn3rp
I have disabled the software for automatically upload and do them manually with the special ADIF. This is until the issue is squared away by eQSL / Log40M
Re: Eqsl SAT MODE
Posted: 28 May 2020, 02:04
by nn3rp
I have written to eQSL support team in an effort to get this "declaration" issue resolve. Hopefully, someone will listen. The more the merrier.
Re: Eqsl SAT MODE
Posted: 14 Jun 2020, 16:50
by EA4GSX
Hello friends
Has the SAT problem in eQsl been fixed with the latest version?
