Error
CU3ED
Error
Post by CU3ED »
Version 2.6.1.0
Re: Error
More explanation of what you were doing at the time, screen shots of which windows were open also please
CU3ED
Re: Error
Post by CU3ED »
Nothing open except the Log4OM, and what I did, was close the log.
Received that error, but unfortunately the text with all the error message was lost...
Here is the log:
2020-05-24 13:51:55.8274 INFO: [#=z4xhVL8lwlwEzUMmvhPh$hcubfOSE] : ##################### USER REQUESTED APPLICATION SHUTDOWN #####################
2020-05-24 13:51:55.9237 WARN: [UCDataGrid][WriteDatagridViewSettings] : Grid not identified (WriteDatagridViewSettings)
2020-05-24 13:51:55.9249 INFO: [#=zweimxOmuBgCTYta6Tw==] : Shutting down Log4OM application
2020-05-24 13:51:55.9262 INFO: [#=zHM$7p7MwKkHdQVVO4g==] : Shutting down Log4OM application
2020-05-24 13:51:55.9262 INFO: [#=zweimxOmuBgCTYta6Tw==] : Saving form status...
2020-05-24 13:51:55.9274 INFO: [ProgramScheduler] : Terminating program scheduler...
2020-05-24 13:51:55.9287 INFO: [#=zweimxOmuBgCTYta6Tw==] : Scheduler closed
2020-05-24 13:51:55.9299 INFO: [LOTWManagement] : [LOTW] Searching QSO in Requested status for upload to LOTW...
2020-05-24 13:51:57.1237 INFO: [LOTWManagement] : [LOTW] No QSO found for automatic upload searching QSO in Requested status
2020-05-24 13:51:57.1237 INFO: [#=zzQ2FK1Wb4h7Qq1vEFGAk1h4=] : Closing UDP listener on port 12040 for service JTALERT/JT_MESSAGE
2020-05-24 13:51:57.1237 INFO: [#=zzn00NJC24Ldmgjs_a7fI2NM=] : Closing remote control on port 2241
2020-05-24 13:51:57.1249 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
2020-05-24 13:51:57.1249 INFO: [#=zzQ2FK1Wb4h7Qq1vEFGAk1h4=] : Closing UDP listener on port 2333 for service WSJT/ADIF_MESSAGE
2020-05-24 13:51:57.1249 INFO: [OmnirigEngine] : OmniRig2 Stopped successfully. Timeout: False
2020-05-24 13:51:57.1249 INFO: [#=zzQ2FK1Wb4h7Qq1vEFGAk1h4=] : Closing UDP listener on port 12060 for service N1MM/N1MM_MESSAGE
2020-05-24 13:51:57.1262 INFO: [#=zweimxOmuBgCTYta6Tw==] : Waiting pending asynchronous activities...
2020-05-24 13:51:57.1274 INFO: [#=zweimxOmuBgCTYta6Tw==] : Starting backup...
2020-05-24 13:51:57.1299 INFO: [BackupManagement] : Starting backup process
2020-05-24 13:51:58.3225 INFO: [BackupManagement] : Backup folder is set to C:\ONE\OneDrive..\..\LOG4OM_DB\BCK\
2020-05-24 13:51:58.3225 INFO: [BackupManagement] : Backup monthly folder is set to C:\ONE\OneDrive..\..\LOG4OM_DB\BCK\Historic\
2020-05-24 13:51:58.3287 INFO: [AdifManagement] : Begin export to ADIF file: C:\ONE\OneDrive..\..\LOG4OM_DB\BCK\.._20200524_135158_backup.adi
2020-05-24 13:51:59.2837 INFO: * [AdifManagement][955 ms] : Export to ADIF file completed
2020-05-24 13:51:59.2837 INFO: [BackupManagement] : Backup created: C:\ONE\OneDrive..\..\LOG4OM_DB\BCK\.._20200524_135158_backup.adi with file size of 20701340 bytes
2020-05-24 13:51:59.3025 INFO: [BackupManagement] : Backup copied to : C:\ONE\OneDrive..\..\LOG4OM_DB\BCK\Historic\.._mai20_backup.adi with file size of 20701340 bytes
2020-05-24 13:51:59.3112 INFO: [BackupManagement] : Backup copied to : M:\Log4OM_BCK\.._20200524_135158_backup.adi with file size of 20701340 bytes
2020-05-24 13:51:59.3125 INFO: [BackupManagement] : Backup copied to : C:\ONE\OneDrive..\..\LOG4OM_DB\BCK\Historic\.._mai20_config.json with file size of 22656 bytes
2020-05-24 13:51:59.3150 INFO: [BackupManagement] : Backup copied to : M:\Log4OM_BCK\.._135158_config.json with file size of 22656 bytes
2020-05-24 13:51:59.3150 INFO: * [BackupManagement][2185 ms] : Backup process terminated
2020-05-24 13:51:59.3162 INFO: [#=zweimxOmuBgCTYta6Tw==] : Backup completed
2020-05-24 13:51:59.3175 INFO: [#=zweimxOmuBgCTYta6Tw==] : Closing user profile...
2020-05-24 13:51:59.3175 INFO: [Initialization] : Closing running user profile
2020-05-24 13:51:59.3175 INFO: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
2020-05-24 13:51:59.3175 INFO: [OmnirigEngine] : OmniRig2 Stopped successfully. Timeout: False
2020-05-24 13:51:59.3187 INFO: [#=zweimxOmuBgCTYta6Tw==] : User profile closed
2020-05-24 13:51:59.3187 INFO: [ProgramScheduler] : Saving system scheduler configuration in file C:\Users\..\AppData\Roaming\Log4OM2\scheduler.xml
2020-05-24 13:51:59.3225 INFO: [ProgramScheduler] : Saving user scheduler configuration in file C:\Users\..\AppData\Roaming\Log4OM2\user\scheduler_49a98dabdd73417f93dc19f1768342fa_user.xml
2020-05-24 13:51:59.3237 INFO: [#=zweimxOmuBgCTYta6Tw==] : Scheduler saved
2020-05-24 13:51:59.3237 INFO: [#=zweimxOmuBgCTYta6Tw==] : Closing windows...
2020-05-24 13:51:59.3250 INFO: [#=zb2_gIdQ59HezJNi5glnWG4ixS_mE] : Saving program configuration
2020-05-24 13:51:59.3250 INFO: [ConfigurationLogic] : Saving program configuration in: C:\Users\..\AppData\Roaming\Log4OM2\user\config.json
2020-05-24 13:51:59.3487 INFO: [ConfigurationLogic] : Program configuration saved
2020-05-24 13:51:59.3487 INFO: [#=zweimxOmuBgCTYta6Tw==] : Program configuration saved
2020-05-24 13:51:59.3512 INFO: [#=zweimxOmuBgCTYta6Tw==] : Unregistering events...
2020-05-24 13:51:59.3537 INFO: * [#=zHM$7p7MwKkHdQVVO4g==][3427 ms] : Shutdown completed
2020-05-24 13:51:59.3537 INFO: [#=zweimxOmuBgCTYta6Tw==] : Shutdown completed.
2020-05-24 18:30:59.4383 INFO: [LogWriter] : ######################################################################################
2020-05-24 18:30:59.4583 INFO: [LogWriter] : ############## LOG STARTED UI ##############
2020-05-24 18:30:59.4583 INFO: [LogWriter] : ######################################################################################
2020-05-24 18:30:59.4583 INFO: [#=zZbWgfca5KwwVGCEkxw==] : Log4OM Next Generation (V2) version: 2.6.1.0
2020-05-24 18:30:59.4683 INFO: [#=zZbWgfca5KwwVGCEkxw==] : Status file loaded
This was from the LOG4OM log file.
All the best,
Re: Error
Did this happen just once or every time you close the program?
CU3ED
Re: Error
Post by CU3ED »
At this moment, 2 times...
Re: Error
CU3ED wrote: 24 May 2020, 23:14 At this moment, 2 times...
What other programs were also running
CU3ED
Re: Error
Post by CU3ED »
Like I said before, nothing, only the log.
This is the main PC, and everything connected to the radio is on another PC, the log is on the main PC and just receive the info by UDP, that's it.
David
Re: Error
David,
So what were the programs in the background of you screenshot?
CU3ED
Re: Error
Post by CU3ED »
Yes, Terry you are kinda right...
That was Mozilla Firefox on the page https://hamspots.net/ that I did open after the error to check for activity on FT8, and when I took the Print Screen the webpage was there, but when I closed the Log4OM both times, there was nothing running.
David
Re: Error
In Program config/program settings, set 'Default log level' to 'Trace'
Run the program and next time it throws the error send me the log file BY EMAIL - DO NOT POST HERE
Having sent me the trace log revert back to 'iNFO' in the program config because it does slow things down
