LOTW auto upload not working.
KE4BCN
Post by KE4BCN »
Since updating to the newest version my auto upload to LOTW quit working. The other auto uploads work fine. The settings are the same as before. Has something changed that may cause this? I am also using latest version of JTalert which I installed this morning.
DJ4JZ
Re: LOTW auto upload not working.
Post by DJ4JZ »
I think the problem is that the default setting is not accepted. Therefore there is no upload.
If you enter Requested manually in the QSO field LOTW, then the upload works.
73 de DJ4JZ
KE4BCN
Post by KE4BCN »
Thank you for the reply. I know it works manually. Qrz and LOTW and Clublog use to say requested when a new callsign was entered and once it was uloaded it would change to yes. Right now Clublog is the only one working correctly. Qrz says no before uploaded then says yes once it has been uploaded LOTW does neither. I was just wondering what changed.
Have you set this correctly?
KE4BCN
Post by KE4BCN »
Hi, yes I did try that same thing
KE4BCN wrote: 09 Jun 2020, 22:33 Hi, yes I did try that same thing
Set Trace mode, emulate your issue and then email me a support request with reference to this thread please
Email it to me at g4pop (AT) arrl.net - DO NOT POST IT ON THE FORUM
