When I try to update my references on "Edit QSO" window, the awards drop-down list is empty, no award is suggested to select reference to add. I'm afraid I'm doing something wrong, or my settings are not correct but couldn't find a solution. Can someone put me in the right direction? I run version 2.7.0.0 on a 32-bit Win7 system, without any additional software. Thanks.
73. Janos, HA4FY
Add/edit my references
Re: Add/edit my references
Hi Terry.
Thanks for the quick response. Yes, I did. Award manager and edit references work well, I even managed to add some custom award, but with my references I'm stuck. I imported my SOTA QSOs ADIF with field MY_SOTA_REF. It appears on my references, but to add manually another reference (e.g WFF or WCA) not present in ADIF is impossible.
73. Janos
73. Janos
73! János HA4FY
It wasn't but I installed it. It is now. How can I send to you the ID and PW?
73! János HA4FY
OK. I found you. I'm on now, you can call or write anytime it suits you.
73! János HA4FY
Though I am still hoping for your help, I am trying to find a solution. There seems to be a problem with ADIF import. Everything works well for the QSOs entered during everyday operation via QSO entry windows. But during contests and portable operation, I use another logging program with subsequent ADIF import into Log4OM. Problem with editing my references occurs for these imported QSOs. I use only one profile for all QSOs, maybe this causes the problem, but I don't know how to solve.
73! János HA4FY
Thanks to Terry's help it solved. The error was caused by the corruption of my SQLite database. After creating a new database and re-importing QSOs from ADIF backup everything works as it should.
73! János HA4FY
