Page 1 of 2
MS edit report
Posted: 17 Jun 2020, 00:50
by OK2DTF
I have problem now in v2 with RST for FSK441 and MSK144 modes. By editing QSO are always RST set as 599 and i have right changed it. It worked in v1 but now in v2 i can't write RST more, only select RST between 111 that 599 by FSK441. If i need set RST 26, after select 261, 262, 263 etc :?: It's strange and by MSK144 now in v2 is still hard :!: :!: :!: I make rcvd QSL cards and i can't edit all FSK441 and MSK144 QSO's because i can't set right RST back :!: :evil: Thansk for help :!:
Re: MS edit report
Posted: 17 Jun 2020, 06:05
by DF5WW
Hello OM,
everybody can do changes in the rst.xml file in the configuration folder. Insert MSK144 and FSK441 to the JT Modes
group in that file and save it as rst_user.xml in the same folder. In next update the rst_user.xml will not be overwritten
but it overrides the original rst.xml.
Here´s the changed file for you. Download it and put it in your Log4OM2 configuration folder (You find via Help
menu). If you open the folder via Log4OM2 you have to restart the program.
rst_user.xml
(24.09 KiB) Downloaded 287 times
Re: MS edit report
Posted: 19 Jun 2020, 19:47
by OK2DTF
Work much better after edit but i'm not sure if is right, mainly work! ;) I changed at 1st RST in "DIGITAL" and worked not right, always bad RST but now it looked like RST same as by MSK144 mode. I added at 1st too to "JTx modes (JT*, ROS*)" new mode FSK315. I copied my changed all RST from "DIGITAL" and copied to "+00". With this change is still ok by FSK441 mode and not rewritten but FSK315 missing always. Need add to main sw? Go not add to XML only? Drahos
Re: MS edit report
Posted: 20 Jun 2020, 08:14
by DF5WW
For FSK315 add the two attached files to the configuration directory. Close and restart Log4OM.
If you don´t see it in the dropdownlist in the Mode field in main UI window it could
be possible you have to go to Settings/User preferences to activate it.
modelist_user.csv
(3.26 KiB) Downloaded 280 times
rst_user.xml
(24.12 KiB) Downloaded 273 times
Re: MS edit report
Posted: 20 Jun 2020, 17:37
by OK2DTF
Augezeichnet! Jetzt funktioniert es perfekt! Kurz zum Thema CW. Warum bei "CW" sind RST von 111 wenn immer auf 9 beendet muss? Logisch sind RST 119/129/139...319/329/339...usw. bis zu 599. Ich hab geändert und perfekt. Im sw MSHV für Meteorscatter sind auch Mode JTMS und MSKMS zu benutzen und Zeit von Zeit kommt QSO aber jetzt schon erledigt. Noch eine Frage stellen von andere Seite. Wenn QSO editiert ist, dann links unten geht Freq und RX Freq eingeben. Nach dieser Freq zeigt welcher Band und RX Band ist aber bei 23cm Band (vieleicht bei andere höher Bänder ist das gleiche aber bin nur derzeit bis 23cm QRV) zeigt das nur im Hauptfenster. Wenn QSO editieren haben, dann kein Band und RX Band zu sehen wenn Freq und RX Freq z. B. 1296181 000 (Hz) aufgeschrieben ist. Frequenz 1296.181 oder 1296,181 funktioniert nicht, dann wie muss teoretisch Freq und RX Freq aufgeschieben werden und danach richtig Band mit RX Band schon sehen? Es geht per Hand wählen aber bei Edit QSO hat wieder verliert! Danke voraus. 73
Re: MS edit report
Posted: 20 Jun 2020, 19:28
by DF5WW
ADIF standards ...
Re: MS edit report
Posted: 24 Jun 2020, 05:16
by OK2DTF
...und wie das mit Frequenz geht? ;)
Re: MS edit report
Posted: 24 Jun 2020, 06:29
If your going to post in the English section please confine your posts to the English language, otherwise post in the appropriate language section.
Re: MS edit report
Posted: 01 Aug 2020, 18:53
by OK2DTF
again problem with MODE set in rst-user.xml. in 2.7.0 worked my file perfect but in 2.8.0 not fully. in modes in log4 is now mode fsk31. in original rst.xml is not add and with my rst-user.xml is fsk315 ignored. i can't select more because by edit QSO in window mode is clear :-(
Re: MS edit report
Posted: 08 Aug 2020, 14:42
by OK2DTF
Problem with FSK315 and MSKMS modes is solved! In file MODELIST.CSV add modes in line 141 3 times FSK315 and in line 142 3 times MSKMS and save. After start Log4OM are new modes in list to see but easy add modes FSK315 and MSKMS to RST_USER.XML file file work not! Need add to MODELIST.CSV file!!! 73's
