Load/save filter capabilites, possible issue.
Posted: 02 Jul 2020, 15:28
I create a filter using a custom query ie sql code .
My sql filter: qsodate>current_date
The filter works, ok!
I save the filter, ok!
I Check the Json file and it contains the code created, ok!
Issue: It does not load the filter that had been created using a custom query.
A filter made using "Use Parms", loads perfect.
The issue is with filters made using a custom query.
(Log4om V 2.8.0.0 - Windows10 32b)
