Adding QSO to log from WSJT-X/JTAlert
Posted: 02 Jul 2020, 21:40
I have had this happen twice today with the new version 2.8 of Log4om. The last instance was when i worked AB1WG on 20M FT4. When the QSo concluded i clicked on the button in WSJT to add the contact to the logbook. Nothing happened. I was watching the recent QSO's for it to show up. Never did. When i manually entered his call into the "Callsign" block ii of course populated the fields. I tried to add the qso from the main field but nothing showed up in the recent QSO's column. When i went and looked at the worked before the qso was there. This happened earlier when i tried to log one of the K2* stations, same sequence of events.
This is the first time i've seen this happen and my upgrade was from the last version. 2.7.
Larry W0OGH
Larry W0OGH
