I would really like to see the following if others also feel that these are useful?
1. A larger FREQ display on the QSO Info pane or maybe visable somewhere else so that it is visable on all panes, but fairly large. the present display is quite hard to see.
2. The other windows such as the map are a fixed size, and if you want to say look at a previous list of times that you have contacted someone, it only displays 5 lines of text, it would be useful to move the map down so that you can see more.
Thats all
James
Visual Layout.
Re: Visual Layout.
IT would be nice to have the map outside the log frame; for ohter window/frame , you have the option detach: would not be possibile detaching map too ?
let wait a feedback from development team !
73 de Don IK2EGL
Re: Visual Layout.
MD0MDI wrote:1. A larger FREQ display on the QSO Info pane or maybe visable somewhere else so that it is visable on all panes, but fairly large. the present display is quite hard to see.
This has already been requested on the forum and is on our list for future development
You can detach the worked before window and make it as large as you want2. The other windows such as the map are a fixed size, and if you want to say look at a previous list of times that you have contacted someone, it only displays 5 lines of text, it would be useful to move the map down so that you can see more
Re: Visual Layout.
G4POP wrote:You can detach the worked before window and make it as large as you wantMD0MDI wrote: 2. The other windows such as the map are a fixed size, and if you want to say look at a previous list of times that you have contacted someone, it only displays 5 lines of text, it would be useful to move the map down so that you can see more
Like this
- Screenshot 2014-03-20 23.05.47.png (126.4 KiB) Viewed 7572 times
Re: Visual Layout.
Sorry to ask Terry, but How ???
Again New to this but I cannot seem to drag any windows out of the frames so to speak and I can make things larger, but they stay next to each other, just would be nice to customize multi-monitor look.
If you could let me know what you do to achieve this I would be much appreciated...
James (MD0MDI)
James (MD0MDI)
Re: Visual Layout.
Doh! Yep seen it, blummin obvious really! Sorry for this one...
James (MD0MDI)
James (MD0MDI)
