How to upload to LOTW?
SM5MEK
Post by SM5MEK »
:?: I tryed the way as was on other place on this forum but it did not worked. Last row is telling me it is something wrong : ERROR: signature and the upload failed. The specified executable is not a valid application for this OS platform.
I am using Windows 7 and crome. Any good :idea:
For now 73 de SM5MEK Jenny :roll:
Re: How to upload to LOTW?
You have a problem with either
The TQSL.EXE
Your certificate for LOTW has a problem
Maybe you have the wrong path to the TQSL.EXE in the Log4om options/external logs
ik2egl
Post by ik2egl »
I am using wondows 7 too and last release of TSQL ; all is fine
some checks you can do:
did you tried an sing and upload a lotw file using tsql out of log4om ?
when you insert the password in log4om configuration windows did you cu&paste it from word (as for esample) or did you insert manually (manuality avoid invalid chars to be pasted) ?
did you do a download QSL from LOTW too in log4om ?
73 de Don IK2EGL
SM5MEK
Post by SM5MEK »
My misstake, of course. The file to trusted qsl program wasent correct. Now i try it when i have some new to load up.
Tnx for the help and cu on the waves.
72 de SM5MEK Jenny.
