DX Cluster Spot
WA2SQQ
DX Cluster Spot
Post by WA2SQQ »
Using 2.8.0.0 - just discovered that sending DX Cluster spot not working. It was working OK before the last update.
Re: DX Cluster Spot
In my case it´s working fine also with the latest 2.8.0.0.
Have you checked the list with your active clusters (if you use more than one).
Only the first cluster in this list will be receive the sended spot. If it´s a cluster
which needs a login are the login data there and correct ?
WA2SQQ
Re: DX Cluster Spot
Post by WA2SQQ »
It's been working just fine since day 1. The problem only started since the last update. I checked all you mentioned and they look OK
