QSO forwarding
KE4BCN
QSO forwarding
Post by KE4BCN »
Does Log4OM support this?
Screen Shot 08-02-20 at 09.43 AM.PNG (7.29 KiB) Viewed 3267 times
Re: QSO forwarding
KE4BCN wrote: 02 Aug 2020, 13:49 Does Log4OM support this?
Ross,
Download the "current" User Guide dated: 01/08/2020 7:52AM Terry just updated it yesterday.
Go to: Help / User Guide / English (force update) ... the most current UG will download and open in your preferred PDF viewer.
Once you have that downloaded go to Page 169. Terry has an explanation of logging automatically to Log4OM Version 1. You can likely use this information to get inbound/outbound set up as you are seeking.
KE4BCN
Re: QSO forwarding
Post by KE4BCN »
The reason for asking is that I like DM780 for the digital modes and to log qso's I have to use hrd logbook which has the option to forward qso's to other programs. I prefer Log4OM for logging.
Re: QSO forwarding
KE4BCN wrote: 02 Aug 2020, 14:51 The reason for asking is that I like DM780 for the digital modes and to log qso's I have to use hrd logbook which has the option to forward qso's to other programs. I prefer Log4OM for logging.
Ross,
Just continue reading then in the UG about UDP Inbound to Log4OM V2. We use such for data from the FTx apps.
We have an outline for N1MM inbound. All noted in the UG. There may be a solution for you there.
KE4BCN
Re: QSO forwarding
Post by KE4BCN »
Thanks for your input, just not sure what ports to use.
Re: QSO forwarding
The message says it's sent in XML format we accept data in ADIF format, you could send to N1MM then forward from N1MM to Log4om but that's getting messy.
KE4BCN
Re: QSO forwarding
Post by KE4BCN »
Thanks same me a bunch of headaches.
