Ron/Aldo
The Omnirig ini file for your rigs have CW-U and CW-L these being used dependent upon the band change chosen
You can edit the ini file in Notepad and save it again as an ini file
The rig descriptor ini files reside in the Afreet/Omnirig/Rigs folder which is in the Windows Program files folder
The filter bandwidths for each mode are probably set in the rig menus, Omnirig is not setting your filter widths as far as I can see
Here is the ini file contents for the 7200 (7000 is almost identical) and as you will see there is nothing related to filter width
; Icom IC-7200 command set
; File created by Uwe Lauer,
[email protected]
; Tested (for Faros) by: ulauer
; initialize
[INIT1]
[INIT2]
[INIT3]
; set frequency
[pmFreqA]
;VFO A frequency
;not supported
[pmFreqB]
;VFO B frequency
;not supported
[pmFreq]
;operating frequency
Command=FEFE76E0.05.0000000000.FD
Value=5|5|vfBcdLU|1|0
ReplyLength=17
Validate=FEFE76E0050000000000FD.FEFEE076FBFD
[pmRitOffset]
;RIT offset frequency
;not supported
[pmRit0]
;not supported
[pmPitch]
;CW pitch frequency
Command=FEFE76E0.1409.0000.FD
;300Hz=0 600Hz=128 900Hz=255
Value=6|2|vfBcdLU|0.425|-127.5
ReplyLength=15
Validate=FEFE76E014090000FD.FEFEE076FBFD
; set rit/xit/split/rx/tx
[pmSplitOn]
Command=FEFE76E0.0F01.FD
ReplyLength=13
Validate=FEFE76E00F01FD.FEFEE076FBFD
[pmSplitOff]
Command=FEFE76E0.0F00.FD
ReplyLength=13
Validate=FEFE76E00F00FD.FEFEE076FBFD
[pmVfoA]
;not supported
[pmVfoB]
;not supported
[pmVfoEqual]
Command=FEFE76E0.07A0.FD
ReplyLength=13
Validate=FEFE76E007A0FD.FEFEE076FBFD
[pmVfoSwap]
Command=FEFE76E0.07B0.FD
ReplyLength=13
Validate=FEFE76E007B0FD.FEFEE076FBFD
[pmVfoAA]
Command=FEFE76E0.0700.FD
ReplyLength=13
Validate=FEFE76E00700FD.FEFEE076FBFD
[pmVfoAB]
;not supported
[pmVfoBA]
;not supported
[pmVfoBB]
Command=FEFE76E0.0701.FD
ReplyLength=13
Validate=FEFE76E00701FD.FEFEE076FBFD
[pmRitOn]
ReplyLength=13
[pmRitOff]
ReplyLength=13
[pmXitOn]
;not supported
[pmXitOff]
;not supported
[pmRx]
Command=FEFE76E0.1C00.00.FD
ReplyLength=14
Validate=FEFE76E01C0000FD.FEFEE076FBFD
[pmTx]
Command=FEFE76E0.1C00.01.FD
ReplyLength=14
Validate=FEFE76E01C0001FD.FEFEE076FBFD
; set mode
[pmCW_U]
Command=FEFE76E0.0603.FD
ReplyLength=13
Validate=FEFE76E00603FD.FEFEE076FBFD
[pmCW_L]
Command=FEFE76E0.0607.FD
ReplyLength=13
Validate=FEFE76E00607FD.FEFEE076FBFD
[pmSSB_U]
Command=FEFE76E0.0601.FD
ReplyLength=13
Validate=FEFE76E00601FD.FEFEE076FBFD
[pmSSB_L]
Command=FEFE76E0.0600.FD
ReplyLength=13
Validate=FEFE76E00600FD.FEFEE076FBFD
[pmDIG_U]
Command=FEFE76E0.0608.FD
ReplyLength=13
Validate=FEFE76E00608FD.FEFEE076FBFD
[pmDIG_L]
Command=FEFE76E0.0604.FD
ReplyLength=13
Validate=FEFE76E00604FD.FEFEE076FBFD.
[pmAM]
Command=FEFE76E0.0602.FD
ReplyLength=13
Validate=FEFE76E00602FD.FEFEE076FBFD
[pmFM]
;not supported
; read status
[STATUS1]
Command=FEFE76E0.03.FD
ReplyLength=17
Validate=FEFE76E003FD.FEFEE076.03.0000000000.FD
Value1=11|5|vfBcdLU|1|0|pmFreq
[STATUS2]
Command=FEFE76E0.04.FD
ReplyLength=14
Validate=FEFE76E004FD.FEFEE076.04.0000.FD
;is filter byte appended to the mode byte?
Flag1=000000000000.0000000000.FF.0000|000000000000.0000000000.03.0000|pmCW_U
Flag2=000000000000.0000000000.FF.0000|000000000000.0000000000.07.0000|pmCW_L
Flag3=000000000000.0000000000.FF.0000|000000000000.0000000000.01.0000|pmSSB_U
Flag4=000000000000.0000000000.FF.0000|000000000000.0000000000.00.0000|pmSSB_L
Flag5=000000000000.0000000000.FF.0000|000000000000.0000000000.08.0000|pmDIG_U
Flag6=000000000000.0000000000.FF.0000|000000000000.0000000000.04.0000|pmDIG_L
Flag7=000000000000.0000000000.FF.0000|000000000000.0000000000.02.0000|pmAM
Flag8=000000000000.0000000000.FF.0000|000000000000.0000000000.05.0000|pmFM
[STATUS3]
Command=FEFE76E0.1409.FD
ReplyLength=16
Validate=FEFE76E01409FD.FEFEE0761409.0000.FD
Value1=13|2|vfBcdBU|25|300|pmPitch
[STATUS4]
Command=FEFE76E0.1C00.FD
ReplyLength=15
Validate=FEFE76E01C00FD.FEFEE076.1C00.00.FD
Flag1=00000000000000.00000000.0000.01.00|pmTx
Flag2=00000000000000.00000000.0000.0F.00|00000000000000.00000000.0000.00.00|pmRx
