WCF connection
Posted: 02 Apr 2014, 17:14
by MW0TBP
Hi, Just downloaded the software but am unable to get the WCF connection to work. Running Vista, have enabled admin rights but will not connect. Settings - services has WCF services stopped, clicking green start button and nothing happens. I am ok but not the best with a pc, any advice please.
Regards
Tony
Re: WCF connection
Posted: 02 Apr 2014, 20:11
Hi Tony, we usually ask users to register with their call, so we can provide a more precise support, if possible from the same time zone :-)
Please check your log file, you can open the folder with files the latest of help menu.
If Log4OM has troubles connecting via wcf is usually a antivirus issue.
If your log report "actively refuse" the connection probably the point.
New release will not use wcf anymore between communicator and Log4OM, keeping wcf for external services, but a firewall will block tcp also.
Please check log and let us known
Daniele IW3HMH
Re: WCF connection
Posted: 02 Apr 2014, 20:41
by MW0TBP
Hi Daniele and thank you for the reply. No log shows when I go to help/show log, not sure if that is the reason it will not connect. All other features seem to work.
Would it be a good idea for me to re-register under my call sign?
Regards
Tony MW0TBP
Re: WCF connection
Posted: 02 Apr 2014, 20:51
I will change your username into your call.
Version 1.16 has a known bug on the show log :? You must use the show config folder function and open the log subfolder. You will find here all the logs. Thanks and welcome
Re: WCF connection
Posted: 02 Apr 2014, 21:31
by MW0TBP
Hi Daniele, Thanks for the help. Looked in the log and found this entry...
014-04-02 16:08:04.0630 INFO: FormSettings: WCF SERVICE Start request issued by user
2014-04-02 16:08:04.2110 INFO: WCFManagement: RunServices starting with path localhost:8080/log4om
2014-04-02 16:08:04.2130 DEBUG: WCFManagement: using HTTP http://localhost:8080/log4om
2014-04-02 16:08:05.6720 INFO: WCFManagement: Opening
2014-04-02 16:08:07.0060 INFO: WCFManagement: Faulted
2014-04-02 16:08:07.0310 ERROR: *** WCFManagement: RunServices start exception ******* [Function: RunServices] System.ServiceModel.AddressAccessDeniedException: HTTP could not register URL http://+:8080/log4om/. Your process does not have access rights to this namespace (see http://go.microsoft.com/fwlink/?LinkId=70353 for details). ---> System.Net.HttpListenerException: Access is denied
at System.Net.HttpListener.AddAllPrefixes()
at System.Net.HttpListener.Start()
at System.ServiceModel.Channels.SharedHttpTransportManager.OnOpen()
--- End of inner exception stack trace ---
I have turned anti virus off but still no joy, sorry I have had to come back with same problem.
Regards
Tony MW0TBP
Re: WCF connection
Posted: 02 Apr 2014, 21:38
Tony,
It seems that you are not running Log4om as an administator.
Full instructions of how to do this are in the user manual
Re: WCF connection
Posted: 02 Apr 2014, 22:01
by MW0TBP
Thank you Terry and Daniele, thought I had sorted the admin bit out, working now and I could kick myself. Want to set it up with Fldigi next but not tonight!
Looks a great programe and I am looking forward to seeing it all up and running, thanks again both for the help.
Regards
Tony MW0TBP
Re: WCF connection
Posted: 02 Apr 2014, 22:04
Hi Tony,
That's good news
FLDigi setup is covered in the user guide but if you have problems let us know
