PST Rotator
Posted: 11 Dec 2020, 14:57
by G0VQY
I have recently installed the logbook and PST rotator on a laptop. I've got slightly stuck with the settings in UDP outbound connections. I've got the PST rotator listed in UDP outbound connections but it still won't work. Do I have to put something into the IP address, maybe the IP address that is in the PST rotator settings?
Re: PST Rotator
Posted: 11 Dec 2020, 16:00
by CT1BXX
I have PSTrotator and works tine with Log4OM.
If you permit remember two important things:
1 You need inform PSTRotator (Setup) you are using Log4om.
2 In PSTRotator in Mode, you need select "Tracking"
Perhaps you have already done it, but in case...
Have a nice weekend
Re: PST Rotator
Posted: 11 Dec 2020, 19:00
by G0VQY
In the UDP outbound settings I entered in 12040 under port. I called it PST rotator and selected PST rotator from the service type. I can't remember, do I have to put something in the destination IP address field?
Re: PST Rotator
Posted: 11 Dec 2020, 21:47
by CT1BXX
Hi Penn
I will tell you about my experience.
The configuration is simple and if you strictly follow the Log4OM Manual, everything will be fine, not forgetting to check the details I mentioned before, in PSTRotator:
In Tracker you must select Log4OM
Mode: Tracking
