qrz.com time problem
ta4va
Post by ta4va »
Hi. Im use log4om app. All my QSO are transferred to qrz.com via API.
But when I check the log records, while the date and time appear correct, all hours on qrz.com appear to be 00:00.
QRZ Logbook: https://prnt.sc/w13ofx
Log4Om Sending Log: https://prnt.sc/w13pa1
When I check, there is no problem with clublog and lotw uploads.
Message from: QRZ Support Team
Sent: 2020-12-12 18:38:35
I'm sorry for any trouble. You will need to contact Log4Om to troubleshoot this issue. Thank you for using QRZ.
What is your opinion on this?
Re: qrz.com time problem
Well its working fine for me see QSO made minutes ago and its on QRZ with correct time
Of course you dont inform us of which Log4OM release your using so we dont have much to go by and the Log4OM log file may point you to your issue.
The fact that you are the only person reporting this and that it tests OK here would indicate the issue is on your PC, perhaps firewall or something set up incorrectly
ta4va
Post by ta4va »
PROBLEM SOLVED
Hi.
This problem is experienced in Windows 10 Turkish local date time settings.
Changing the system's default date and time setting to "English US" or "English UK", the problem goes away.
ta4va wrote: 15 Dec 2020, 20:37 PROBLEM SOLVED
Hi.
Well done
