QSL sent or received Date
Posted: 17 Dec 2020, 14:01
by F6FLU
today I Sent my QSLs requested for ET3AA via OQRS (N2OO)
Now I would like to see this Sent Date on my logbook
I don't see this possibility
When I make a search via the menu (QSL Manager) I see these Fields (Sent Date and Received Date)
- Log4om Sent Date and Received date 2020-12-17 114551.jpg (109.82 KiB) Viewed 2999 times
I would like to display these fields in the "Recent QSO '" tab and in the "Worked before" tab is this possible
if not, could it be considered to display these 2 fields
Thanks and 73
Re: QSL sent or received Date
Posted: 19 Dec 2020, 14:14
by F6FLU
It's surprizing, 34 views no comment, "nobody cares" ?
Posted: 19 Dec 2020, 17:51
by DF5WW
Have you tried to search in the manual ? Think that was 34 views of guys that know how a manual
is working. The fields you are want to display in F7 and in the worked b4 window are possible. Try
to find out something about "Edit Table Layout".
The manual is an PDF and fully searcheable with different PDF readers and to search in the manual
should be the first step before asking everything. Second step should be a search in the forum.
Posted: 19 Dec 2020, 19:57
by F6FLU
Thank you for your reply ...
<Have you tried to search in the manual ?>
==> Yes I did
<The fields you are want to display in F7 and in the worked b4 window are possible>
==> may be but I don't see them, that's why I'm asking the question :
- Capture d’écran 2020-12-19 205353.jpg (40.08 KiB) Viewed 2950 times
- Capture d’écran 2020-12-19 205438.jpg (40.66 KiB) Viewed 2950 times
- Capture d’écran 2020-12-19 205512.jpg (35.77 KiB) Viewed 2950 times
<Try to find out something about "Edit Table Layout".>
==> Yes I searched but I did not find ...
<The manual is an PDF and fully searcheable with different PDF readers and to search in the manual
<should be the first step before asking everything>
==> yes that's what i always did
I feel you are annoyed in your answer, if that annoys you you do not have to answer me ...
Posted: 19 Dec 2020, 19:58
by F6FLU
and the last one
- Capture d’écran 2020-12-19 205257.jpg (36.04 KiB) Viewed 2950 times
Posted: 20 Dec 2020, 07:34
by DF5WW
O.k., my mistake. The send dates you´ll find only in the QSL manager. For the most of the
useres the fields (Send and receive status YES/NO) are enough to see that a QSL is send.
Posted: 20 Dec 2020, 07:44
by F6FLU
yes but as these QSL date sent and qsl date received fields exist, my request is therefore to be able to display these fields in the different Log displays, I think it should not be too complicated...
