'mode' not lockin
G0BPS
'mode' not lockin
Post by G0BPS »
Under 'mode' I have only selected FT8 on the setup but when operating the mode button keeps popping over to USB
I can then 'lock' FT8 but later USB re-appears. Help !!!
Re: 'mode' not lockin
The mode is following the cat control, if you set wsjt and log4om up as listed in our user guide when you log in wsjt it will automatically be saved to log4om with the correct mode.
