Incorrect Country being logged
VK7XX
Post by VK7XX »
I am using version 2.11.0.0 and recently I have noticed a few incorrect countries sneaking in to the log and am wondering if it might be a setting I have missed, or something else, maybe a bug.
As an example, two of the most recent incorrect entries have been :-
DU6/N7MOT where the country was recoded as USA and
DU6/PE1NSQ where the country was recorded as Netherlands
I have previously worked DU6/PE1NSQ about a year ago, and back then the country was recorded correctly.. Any Ideas / clues anyone ???
regards
John
VK7XX
Re: Incorrect Country being logged
Made some test loggings but both show´ n as Phillipines in the lookup and in the log.
VK7XX
Post by VK7XX »
DF5WW wrote: 04 Jan 2021, 04:47 Made some test loggings but both show´ n as Phillipines in the lookup and in the log.
how weird is that..... thanks Juergen... I will do a reboot ans see if this helps
John
How long is it since you updated tour data files Settings/update resources - Do all of them!
VK7XX
Post by VK7XX »
G4POP wrote: 04 Jan 2021, 08:29 How long is it since you updated tour data files Settings/update resources - Do all of them!
According to the blue dot that appears, from memory, they were updated recently however memory may be wrong so I'll do em manually. Thanks Terry
John
