wsjt-x and log4om won't update qrz
Posted: 06 Jan 2021, 20:52
So here are the details. using log4om V2, also using wsjt-x V2.2, icom7300.
connections with omnirig work fine, the radio connection is good.
when I log an SSB contact in log4om it works fine. it will push the QSO record up to qrz.com without issue. when I use wsjt-x and make a contact it gets logged into log4om, but it does not send the QSO to qrz.com. my manual entries for SSB do. I looked here in the forum and also the manual, everything is configured as it should be. what am I missing? has anyone see this issue before?
