Listing a logbook extract
PA0MBD
Post by PA0MBD »
Can somebody give a solution how to make a survey of IOTA's (reference1 in my case), worked but not confirmed. How to select these logbook records? The logbook print facility does not offer a possiblility for printing at random chosen items (like creating a ADIF file).
Using V2.11
As most users are smarter than I am, I look forward to your suggestions.
73 de Martin/PA0MBD
Re: Listing a logbook extract
View/Award statistics - select IOTA award etc etc etc
PA0MBD
Post by PA0MBD »
Tnx Terry, but I am familiar with that. But how to get it on paper?
PA0MBD wrote: 13 Jan 2021, 10:22 Tnx Terry, but I am familiar with that. But how to get it on paper?
Have you tried using the Excel or csv export on the right hand edge of the awards grid?
PA0MBD
Post by PA0MBD »
I have to apologize for my limited possibilities to express myself clearly in english, causing confusion regularly.
The EXCEL-option is a very nice option, giving enough way to manipulate the desired survey on paper. But, as far as I can conclude, using the award status one cannot see the IOTA's worked, but not confirmed. Each confirmed IOTA is also worked, and so presented as worked.
Removing these lines in Excel by hand is in the case of near 800 IOTA's very risky and intensive to investigate.
I suppose the solution is to select all logrecords containing a IOTA-reference (sorting on Reference1 = IOTA), make an ADIF-export of these records and export to a new IOTA-log. Than manipulate that new log by selecting and removing all confirmed (LOTW and QSL).
Terry, what don't I see .....
QSL Manager filter as below
1. References tab set Award to IOTA /Reference (Leave blank)
2. Confirmations tab leave Search confirmation blank but select RCVD to No and check the box
3. close filter dialog
4. Select all
5. Right click on a title field and select an export of your choice
PA0MBD
Post by PA0MBD »
Tnx vy much Terry, I will do the same for LOTW-confirmations.
There are so much options available, and the number of combinations is nearly unlimited ...... It will take time to learn them to use!! :twisted:
