MAIN UI MAP SLOW
Posted: 23 Jan 2021, 02:47
by KH6CT
Greetings...
After double clicking on a callsign in the cluster, I select the main ui map to see more closely where the contact is located. Map on left loads instantly showing line between me and the potential contact. Map on right is extremely slow to load (30 seconds or more). Rolling the mouse wheel will cause erratic action... single click on the mouse wheel will cause a jump from large scale to small scale... once map has rested on a scale of its choice, it is very slow to load (30 seconds or so). Moving the map with a right click and drag seems to work ok. The map never shows the Google Street Level view.
Running Log4OM, Win4Yaesu and SDRConsole. Computer is a Dell i7-4700 @3.4GHz, 16GB ram, 250GB SSD.
Task manager shows only 3 to 5% CPU load for Log4OM with a total load for all other software and services being about 20 25%.
Any thoughts ??
Thanks, Steve KH6CT
Re: MAIN UI MAP SLOW
Posted: 23 Jan 2021, 08:06
Try unchecking these two boxes and see if that improves things
- Untitled.jpg (102.77 KiB) Viewed 1703 times
Posted: 23 Jan 2021, 18:49
by KH6CT
You are a MASTER of software!! Unchecking both solved the problem.
Thank you very much....
Best 73 and Aloha... Steve KH6CT
Posted: 03 Dec 2022, 13:14
by OE1MWW
In my 2.24.0.5 version the destination map never comes up.
Immediately as I enter a call sign into the call sign field, a blue line, pointing towards
the station I entered is shown, but the background map unfortunately never comes up.
Background stays grey ;-(
If there is no call sign in the call sign field, my home location with a map background
comes up pretty fast.
Any hints please, to solve this ?
73's de OE1MWW
Wolfgang
Posted: 03 Dec 2022, 14:52
Did you try zooming out?
Posted: 03 Dec 2022, 18:24
by OE1MWW
G4POP wrote: 03 Dec 2022, 14:52
Zoom out does not help, same 'blind' map.
I changed (but where did I change ?) to OpenStreetMap.
Now I have blue tiles with time out messages.
Internet speed is sufficient, response from QRZ.com comes immediately.
... and now I can't find the setting Google or OpenStreetMap - where did I change this ?
Manual has not entry for that, must be new. Please give me a vector which menu that has
Thanks in advance !
73's de OE1MWW
Wolfgang
Posted: 03 Dec 2022, 19:14
by KI5IO
OE1MWW wrote: 03 Dec 2022, 18:24
Thanks in advance !
73's de OE1MWW
Wolfgang
Wolfgang,
Settings / Configuration / Program Settings ... Select Map Provider (Google Maps, Bing Maps, Open Street Maps)
Has always been there, but additional Map Providers have been added.
Posted: 04 Dec 2022, 08:13
by OE1MWW
KI5IO wrote: 03 Dec 2022, 19:14
Wolfgang,
Thank you Nolan, that was self-trickery. Some major entries in the 'Program Configuration' menu are grayed
out - there are no setting options in the heading there, only in the sub-menus. But in the first two, in black,
'Program Settings' and 'User Configuration' do have entries in the major menu entry.
And these I have skipped. All set now
73's de OE1MWW
Wolfgang
