New Mode Q65
WT0DX
New Mode Q65
Post by WT0DX »
What is the proper modelist.csv entry for the new Q65 (WSJT-X v2.4.0-rc1) mode? Not yet an official ADIF mode...
73 Bill WT0DX
WT0DX
Re: New Mode Q65
Post by WT0DX »
To answer my own question... I added Q65;Q65;Q65.
I also needed to edit the rst.xml file adding <string>Q65</string> to the Mode Type DIGITAL configs.
And you will need to Add Q65 -> DIGITAL to your LOTW TQSL preference ADIF Mode settings.
73 Bill WT0DX
G8LIY
Re: New Mode Q65
Post by G8LIY »
Are you sure..??
Remember the mistake that was made with FT8 ADIF definition..
FT8 should have been a Submode of MFSK, but is now a mode
FT4 is correct Submode of MFSK
So should Q65 be a Submode..??
Just raising this
Windows 10 Pro & LOG4OM - V2.29.0
G8LIY
Re: New Mode Q65
Post by G8LIY »
Just found these posts on the FT8 / FT4 issue from "yesterday" ,, Not sure if Q65 ADIF definition will eventually be affected
Neil Zampella
Due to the time pressure put on the ADIF committee when FT8 was launched in July 2017, FT8 was defined as a MODE, not as a SUBMODE to MFSK, as it should have been. When FT4 showed up, they had better time to consider the technical merits and made a correct definition of the mode/submode in ADIF terms. With the millions and millions of FT8 QSO logged and confirmed in various QSL systems, I believe the FT( mode "error" will never be corrected.
Frode Igland
The ADIF definition of FT4 is that is a submode under MFSK, so unless you insist on the mode being FT4, I suggest you follow the ADIF standard used by thee
logging programs. HRD was a bit slow in gettings these things organized, but now it is very simple to get it to work with correct Mode MFSK and Submode FT4:
Open HRD Logbook, Open Configure - Mode, click on the Defaults button in the menu line, click OK and you are good to go. Mode/Submode will be correct,
and everything will work smoothly with e.g. Logbook of the World.
G8LIY
Re: New Mode Q65
Post by G8LIY »
Sorry for multiple posts... I have not used Q65 or FT4
What is showing in the wsjtx adif log file for mode / sub mode..??
G8LIY
Re: New Mode Q65
Post by G8LIY »
I posed the question in the WSJTX Dev Forum, got this...
Joe Subich, W4TV 18:44 #22470
On 2021-02-20 12:51 PM, neil_zampella wrote:
Its up to the ADIF committee. Based on this quote from the Q65 Quick
Start guide, I suspect it will be a 'mode & submode' entry about the
same as QRA64
Yes, the ADIF developers group has discussed it as Mode=MFSK,
Submode=Q65. I have not seen an official statement, but since the
designation is not controversial I would expect it to be added to
the next update of the standard sometime before WSJTX 2.4.0 has
its official (GA) release (that is no longer a "release candidate").
73, ... Joe, W4TV
G3ZSS
Re: New Mode Q65
Post by G3ZSS »
The latest version of Trusted QSL released today has now been updated to accept Q65. Hopefully the next version of Log4OM will now include Q65 as an option.
73 Peter
73 Peter G3ZSS
Re: New Mode Q65
Not a new TQSL release, a new configuration file. It´s also in the Submode list of ADIF 3.12.
Mode is MFSK and Submode Q65.
