Hey guys,
I'm using the latest Log4OM, WSJT-x, and GridTracker versions. Everything is working fine, except shouldn't the callsigns I'm working show up in the Log4OM callsign field for country, mode, worked before, etc. checks? Currently it goes from WSJT right into my log.
Thanks,
Mike, NT6X
FT8 callsigns not showing up in callsign field
Re: FT8 callsigns not showing up in callsign field
Sounds like you have not followed the set up instructions in the latest user guide.
I reviewed the manual and still cannot get the callsigns to populate the callsign field in Log4OM. My connection tab is below. Maybe a trained eye can spot any conflicts that I'm not seeing.
Mike,
Take a look at this OM's configuration. We've recommended it a number of times.
https://www.k0pir.us/gridtracker-wsjt-x-and-log4om/
Hi Nolan,
Thanks so much for the link. Everything is working great now.
Mike, NT6X
Mike, NT6X
Mike,NT6X wrote: 30 Mar 2021, 01:02 Hi Nolan,
Mike, NT6X
Tnx for follow-up that you got it up/running.
