Startup and Backup Error - "database disk image is malformed"
KD0Q
Post by KD0Q »
Hoping someone can help me fix this.
Backup is failing with: "Backup Error. Check log." The log shows there is also an error at startup having to do with calculating statistics.
OS = Windows 10 Pro build 19041.804
Log4OM 2 Version 2.11.0.0
Log attached.
Any help will be appreciated.
Thanks, Glenn KD0Q
LOG4OM2_log_UI_20210305.log
(16.87 KiB) Downloaded 161 times
Re: Startup and Backup Error - "database disk image is malformed"
You could have a corrupted database, try making a new database and import your last ADIF backup
I notice that you have the database on the C drive of your PC, try creating it in the documents folder or on the cloud
KD0Q
Post by KD0Q »
Thanks Terry.
I'll try rebuilding from last good backup.
The database needs to be local due to unreliable internet. Can create it in local documents folder.
73, Glenn KD0Q
KD0Q
Post by KD0Q »
Backups are working now.
Here's what I did:
1. Exported QSOs after the last good backup to an ADIF file.
2. Rebuilt the database from the last good backup.
3. Imported the QSOs from Step 1.
Thanks for the help.
73, Glenn KD0Q
Glenn,
KUDOs ... and thanks for the follow-up and steps you employed to resolve the issue.
Tnx for using Log4OM V2.
