.csv file
Posted: 10 Mar 2021, 20:29
by KB1FGC
Hi,Were would I find the .csv file that I saved from the QSO manager page? I looked in the config folder but I see several of them.I'm trying to export a CSV file to submit information to NAQCC.
Re: .csv file
Posted: 10 Mar 2021, 20:54
by KI5IO
KB1FGC wrote: 10 Mar 2021, 20:29
Rich,
What did you name the .csv file?
You could do a search from Windows Explorer or any other file manager APP on your computer.
When you saved the .csv file you were prompted for a location so you should have seen that.
Below is a screen clip of a test save I just did for a .csv and it is asking me where I want to save it.
So ... a search with your file manager will likely be your best bet.
Re: .csv file
Posted: 10 Mar 2021, 22:31
by KB1FGC
THanks for the info.Ok I figured it out.I don't know what the bottom icon does "savelog". Also Not sure how to set the CSV field so they can be saved.I will look for that in the manuel.
Re: .csv file
Posted: 11 Mar 2021, 01:38
by KI5IO
KB1FGC wrote: 10 Mar 2021, 22:31
Rich,
The bottom save log icon does just that: It saves the transaction log. Meaning the keystrokes entered in that panel with the event underway are a "log". You can save that log for trouble-shooting issues if need be.
Below is a screen clip of text that is saved in such a log ... if you like or have a need to. I only use for trouble-shooting.
Once you have text in the log panel and have a need to save such a log ... once you tap the Save Log Diskette you will again be prompted for a location (of your choosing) to save the log-file. It will have a ".txt" file extension.
Re: .csv file
Posted: 11 Mar 2021, 02:42
by KB1FGC
Nolan Thanks alot!.Can you tell me how to save the CSV fields?Maybe there isn't a way.But you know how in the Recent QSO page you can save the settings for which columns you want.In the CSV Eport window is there a way to do that?It's not a big deal but convenient.
Re: .csv file
Posted: 11 Mar 2021, 04:03
by KI5IO
KB1FGC wrote: 11 Mar 2021, 02:42
Rich,
Danielle has six basic items selected as the default and you can select any/all you want for any given export, but (at this time) such a selection cannot be saved for use again next time. It defaults back to the basic six items.
