Auto Upload to External Databases
EI5KO
Post by EI5KO »
Hi All,
Quick question re Automatic uploads.
I have Set up Auto uploads to online loggers and works correct if a QSO is saved in Log4OM.
I have also set up ADIF scanning of both WSJT-X and JTDX logfiles which also pulls the saved qso into Log4OM.
My question ... Is the a setting somewhere, that allows uploads that have been scanned from the ADIF to be sent to the External Databases.
At present the QSO's scanned in from the ADIF's although saved in Log4OM do not upload externally...
Thanks for the help.. :D
De EI5KO
Keith.
Re: Auto Upload to External Databases
No ADIF monitor will not activate auto uploads
If you set up WSJT as described in our user guide employing UDP connections the auto upload will function for incoming QSO's
EI5KO
Post by EI5KO »
Thank for the reply Terry..
