v2.12 - FCC-Database download very slow
Posted: 29 Mar 2021, 22:03
by DL2RPN
I've updated to version 2.12 and now the download of FCC-Data is very slow.
My internet speed tool shows 20-25kb/s (but it could be 5MB/s or more...). The file wich is downloaded by LOG4OM2 is: 'c:\Users\xxx\AppData\Roaming\Log4OM2\temp\fcc.zip.tmp'.
The point is, if I close LOG4OM2 the download continues and prevents LOG4OM2 from shutting down. But I cant wait about 2 hours if i want to shutdown the computer...
I don't know if the problem is LOG4OM2 or the server wich is hosting the FCC-Database. It would be nice if LOG4OM2 stop the download at shutdown and continue if its start again.
Re: v2.12 - FCC-Database download very slow
Posted: 29 Mar 2021, 22:49
I just tried the FCC update and its taking about 17 seconds here
Can you try it again in case it was a temporary FCC server issue
Posted: 30 Mar 2021, 17:14
by DL2RPN
Hello Terry,
so, tested again - same issue.
I've attached the logfile. Now, 17:07 UTC the program is still running, download rate is about 25k/s. And the temporary file what i mentioned above have a size of 85MB.
As you can see inside the log, I've give the shutdown at 16:05 UTC. The message at the end related to omnirig is a problem with my CAT-Interface, nothing to do with the fcc-download. But it shows, that the program is running...
Should (and can) I downgrade to v2.11 and try again? I've no idea at the moment what to do.
Thanks in advance.
Chris
[Edit]: My internet connection is ok. 4MB/s should be no problem.
Posted: 30 Mar 2021, 17:28
What happens if you use the Omnirig version 1.19 original instead of the Swiss version that is not supported by Log4OM?
Posted: 09 Aug 2021, 13:26
by DL2RPN
Sry for late answer - I was unable to attend for some reasons.
I've not tried this - but the swiss version is running good... :D
The demon was a switch in my local network wich doesn't work from time to time. It wasn't so easy to determine the failure..
Thanks for your support Terry.
