New Version 2.12
Posted: 01 Apr 2021, 06:12
by DJ9UN
Great to see that many tranceivers have been added into the config. Using FTDX 3000 and having enable the HAMLIB for second VFO. However after a moment my FTDX3000 switch from one VFO to the other. Maybe id did something wrong. Thanks for help
Re: New Version 2.12
Posted: 01 Apr 2021, 07:45
Hi, no you didn't anything wrong.
Hamlib is not perfectly tuned on some rigs, and we had the same issue on some ICOM radios during testing (promptly fixed by Hamlib devs)
I'll report that to the developers, we suggest to stick with Omnirig at this time for your radio
Posted: 01 Apr 2021, 08:30
by DJ9UN
Thank you wen enable the radio is fine but only for sommen seconds. After both RX VFO blinking and switching. All fine i reinstalled the previous Version and using FTDX5000 config for my FTDX3000
Best regards and TNX 73
Posted: 01 Apr 2021, 11:41
by KI5IO
OK8UN wrote: 01 Apr 2021, 08:30
OM,
"Reinstalled the previous version." ????
What previous version? Log4OM V2 or HamLib or just what in particular? You are not clear as to what application you have reinstalled?
Some additional data will be helpful.
Posted: 02 Apr 2021, 09:01
by DJ9UN
The Version 2.11 and i select the FT5000 in the config
73 Alain OK8UN DJ9UN LX1UN
Re: New Version 2.13
Posted: 03 May 2021, 13:05
by DJ9UN
Thank you for updating version 2.12
Duo VFO working great and the FTDX 3000 is communication well with the logging program appart of the mode function who always is in RTTY mode even selecting the RTTY mode away from the settings. I solve it temporary by pselecting LSB on 80 m and locking it in the main view
Regards
Alain
