Hallo,
ich finde keine Möglichkeit, die Ansicht von "worked before" OSO's zu konfigurieren.
Gerade die Spalte ""Comment" lässt sich nicht anzeigen.
73', Stefan
Worked Before
Moderator: DF5WW
Re: Worked Before
Stefan,snet0311 wrote: 05 Apr 2021, 13:07 Hallo,
73', Stefan
With the Worked before (F10) panel open ... right click on the visible column labels and select: Edit table layout.
Another small edit window will appear and you can tic the boxes for the labels/columns you want to appear. Each grid in Log4OM V2 has this option.
- wb4_grid-configuration.JPG (130.83 KiB) Viewed 5147 times
Re: Worked Before
Hi Nolan,
you made my day
Thank You!
73'
you made my day
Thank You!
73'
Re: Worked Before
Stefan,
With any grid panel open you can left-click-hold the column's label and move it left/right where it best works for you. You can also resize the width of the columns.
Works the same as the Excel spreadsheet in Windows when it comes to moving columns, resizing, renaming, etc..
Each grid's adjustment are for "that grid" so each can be personalized.
Re: Worked Before
Hi Nolan,
switched to V2 two weeks ago, so i have to get more familiar with that Version. But it's getting better from day to day
It is always good to know where to start.
Thank you for your help.
Cheers from Munich
Cheers from Munich
Re: Worked Before
Stefan,snet0311 wrote: 05 Apr 2021, 17:12 Hi Nolan,
Cheers from Munich
Welcome aboard to V2. Lots and lots of stuff to absorb ... to say the least. Even being on the Alpha Team I learn plenty each day I use V2.
Be sure to take the time to watch Terry's YouTube videos: https://www.youtube.com/channel/UC6Ppcj ... yavI-azOug
