Duplicate qsos after LoTW sync
Posted: 17 Apr 2021, 10:59
Hi everybody,
I recently started using LoTW, when I have problems when I download qsl confirmations.
I will try to explain.
QSOs are recorded in Log4OM as USB and LSB, but when I sync with LoTW, that probably uses only SSB, those with qsl
get duplicated.
I literally have the same qso but the mode is set to SSB.
Also (but is not a relevant problem) I get a YES on normal QSL and not on LoTW qsl's column, but this can be easily fixed manually.
Last but not least, if I delete the SSB duplicated qso, whenever I try to download confirmations from LoTW,
the qso is created again.
Can someone help me to solve?
73 de Antonio.
get duplicated.
73 de Antonio.
