Loss of configuration
Posted: 30 Apr 2021, 11:43
by PP5XA
Good morning everyone, I was using version 2.12.0 of LOG4OM V2, after installing version 2.13.0, whenever I close the program it loses the user's confusion and the database, returns as if it were the first time I'm entering and I need to configure everything again. Does anyone know how to solve the problem?
Re: Loss of configuration
Posted: 30 Apr 2021, 11:54
by KI5IO
PP5XA+ wrote: 30 Apr 2021, 11:43 Good morning everyone, I was using version 2.12.0 of LOG4OM V2, after installing version 2.13.0, whenever I close the program it loses the user's confusion and the database, returns as if it were the first time I'm entering and I need to configure everything again. Does anyone know how to solve the problem?
This has been answered on several threads. Read the link below and then also click on the link that Terry provided with a search of your same question.
https://forum.log4om.com/viewtopic.php?f=33&t=6611
Posted: 30 Apr 2021, 13:05
by W4WWB
PP5XA+ wrote:whenever I close the program
If accurate this may be a different problem.
Posted: 30 Apr 2021, 14:22
Where is Log4OM stored on your PC, provide paths the user files and also your sqlite database please
Posted: 30 Apr 2021, 15:30
by PP5XA
yes, everything is set up correctly, when I close the program and reopen I need to do everything again, it's like setting it up for the first time!
Posted: 30 Apr 2021, 16:12
That does not answer my question, please state paths and locations
Posted: 30 Apr 2021, 16:18
by PP5XA
my config:C:\Users\User\AppData\Roaming\Log4OM2\user
my database: C:\Users\xxavviiierr\Documents
Posted: 30 Apr 2021, 16:34
PP5XA+ wrote: 30 Apr 2021, 16:18 my config:C:\Users\User\AppData\Roaming\Log4OM2\user
Windows 10?
What other software is running in conjunction with log4om?
Is log4om being run as an administrator?
Posted: 30 Apr 2021, 16:37
by PP5XA
Windows 10? R: yes
What other software is running in conjunction with log4om? R: JTDX
Is log4om being run as an administrator? Yes!
Posted: 30 Apr 2021, 17:05
PP5XA+ wrote: 30 Apr 2021, 16:37 Windows 10? R: yes
Very odd
Please send me a support request from the help menu and include your ADIF
Send to g4pop (at) arrl.net
