icom 7610 filter change after switching station in cluster
Posted: 16 May 2021, 16:38
by pd2mic
hello all..
since yesterday i am an new user of the log4om and i like it alot!!
now everything is running oke, i notice that when i have select an spot in the cluster my filter setting changes from 3.0k to 2.4k
after switching the filter back to 3.0k manual on the radio, and selecting an other station in the cluster the filter switch back again to 2.4k!!
until now i cannot find the awnser why or what in the manual..maybe i read over it!..
can anyone tell me what to do? so the filtersetting stops jumping to 2.4k..
maybe its very easy but i cannot find it now..
thanks..greetings pd2mic..mike
Re: icom 7610 filter change after switching station in cluster
Posted: 16 May 2021, 20:33
by pd2mic
i found it my self!
with the 7610 you can change fil1/2/3 in the bandwith settings..
so you can change the 1.8k/2.4k/3.0k in setting fil1/2/3 just tap the BW and change with the vfo/dial the amount in value..
now at my radio is fil1 1.8k fil2 3.0k fil3 2.4k
hope this will help amateurs in the future..
73 pd2mic mike
