Backup of Table edits
Posted: 22 May 2021, 08:52
by ei3gd
Hello team,
I'm loving this wonderful program, many thanks to all developers! Donation made.
I recently switched PC and needed to re-load the program.
Using the config.json file I was able to recover most of my personal settings.
However it did not recover my fine-tuning changes such as Logbook table edits etc.
Is it possible to capture these edits somewhere for recovery purposes?
Ray
Re: Backup of Table edits
Posted: 22 May 2021, 09:21
In the user folder you will see a number of 'Layout' files marked 'User' copy them all across to the same folder in the new installation
Posted: 22 May 2021, 09:43
by F6FLU
G4POP wrote: 22 May 2021, 09:21
I don't see where is this folder ? and I don't see Layout Files
more details would be very useful
Posted: 22 May 2021, 10:09
F6FLU wrote: 22 May 2021, 09:43
Help/Open config folder click the 'USER' folder, therein are layout files
C:\Users\
YOUR USER NAME\AppData\Roaming\Log4OM2\user
- Capture.JPG (100.07 KiB) Viewed 2293 times
The other person clearly already found the folder because he used the config file but is that enough detail for you?
Posted: 22 May 2021, 10:41
by F6FLU
Thanks Terry
Yes it’s ok now I asked because I did not understand
You said « Layout' files marked 'User' «
I’m looking for some files with theses words Layout AND user...
