Log4OM possibly reporting wrong QRZ.COM data
M0MDS
Post by M0MDS »
I am getting some odd data from QRZ.com
If I look up my callsign M0MDS I get all the right data.
If I look up my M0MDS/MM callsign I don't get the right Maidenhead locator and no country is reported.
I did a test on the QRZ xml tester at
https://xml.qrz.com/xcheck
and it seems to report the correct info. Is Log4OM caching some old data internally?
Mike
Re: Log4OM possibly reporting wrong QRZ.COM data
M0MDS wrote: 26 May 2021, 09:13 I am getting some odd data from QRZ.com
Mike
/MM will not return a grid, DXCC or country because it is used for a station at sea which is not of course in any country and the grid can only be determined by the /MM station providing it at the time of the qso
M0MDS
Post by M0MDS »
Thanks for the reply.
At sea in UK coastal waters is still UK.
An xml query of QRZ does give a country and a locater see below.
M0MDS
M0MDS/MM
M0MDS
Post by M0MDS »
Log4OM reports no country for the /MM but does report the IO91wo location which isn't quite right.
M0MDS wrote: 26 May 2021, 10:21 Thanks for the reply.
M0MDS
M0MDS/MM
No it is not I sail the north sea and as soon as I leave the river I am considered to be at sea according to ham radio, not maritime law which includes the 3 mile limit
Of course it does but it's reflecting the entry not the DXCC rule
How does QRZ know when your in the middle of the Irish sea if your outside the UK coastal waters
Official description
"The following notes are made with regard to the UK "Full" amateur radio licence terms, provisions and limitations, and so may vary slightly from other amateur licences.
Maritime mobile operation is defined as operating a transmitter that is located on any vessel at sea. This means any manned structure afloat outside of the high-water mark. Operating on vessels on inland waterways is defined as mobile working, and so requires /M to be added to the callsign, not /MM as for maritime mobile operation."
