How Do I Add a Mode to the Drop Down Mode Field
Posted: 07 Jun 2021, 13:27
by K4TMG
I have recently started manually logging Satellite QSOs. The mode I need is FM. In the drop down menu on the main screen the only options I have are USB, LSB, FT8 and RTTY. I would like to add FM. I change My Station to the correct radio and antenna and click the Sat mode box and add the sat info. Then I manually entering the Callsign, Times and Frequencies. I save the QSO with the incorrect mode and then quickly before it uploads everywhere else edit the QSO where it gives me the option for all the modes. What am I missing? I have v.2.13.0.0
Re: How Do I Add a Mode to the Drop Down Mode Field
Posted: 07 Jun 2021, 14:07
by KI5IO
K4TMG wrote: 07 Jun 2021, 13:27
Set up your preferred modes in the Configuration Tab ...
Go to:
Settings / Configuration / User Preferences / Preferred Modes
Make your selections and be sure to save and you should be good to go.
Posted: 07 Jun 2021, 15:14
by K4TMG
Thanks! That did the trick.
