breakout log (QSO) screen not refreshing
Posted: 21 Jun 2021, 23:46
by NI4MX
I am running version v2.14.1.0 and if I bring up QSO grid view, new contacts do not show. it does log them, but freezes on refresh. (after program shutdown and restart they show up)If I don't use the QSO grid view everything works normal, logs and refreshes normal. I have tested this on two other other HAM's setups, they have the same results.
reverting back to v 2.13.0.0 corrects the problem.
Re: breakout log (QSO) screen not refreshing
Posted: 22 Jun 2021, 11:22
by KI5IO
Ed,
I relocated your post/topic to the V2 portion of the Forum as you indicated you are using V2 of Log4OM.
Log4OM V1 is under "maintenance". Best to post items related to V2 under that section for best visibility.
Posted: 23 Jun 2021, 11:20
i'm checking that reports
