Something funny going on this evening. I've two user configurations setup, one for the QTH and one for SOTA. When I toggle between them, I have difficulty making one active via the green tick button. Sometimes it works, sometimes it doesn't. Literally toggling between the two configurations with a few seconds is hit or miss.
Also, which may be related, I have difficulty unlocking the time padlock on the QSO entry screen to enter QSO's from the weekend. It just goes to having a blue dotted surround on the padlock, rather than the red padlock. Sometimes it works, but most times it doesn't.
Any suggestions as to where to look? I'm using version 2.15, and have switched between configurations and entered QSO's retrospectively before, so I know it does work. All my previous QSO's are listed, so the db seems ok. CAT is off, disconnected from the cluster and chat is off. I have windows 10. Nothing obvious shows up on the error log, even on trace mode, only "executing planned scheduler" and dump modules every 5 secs and the HRDLog message every minute.
23:37:35.454 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Planned scheduler executed...
23:37:40.46 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Executing planned scheduler...
23:37:40.46 Trace: [LogWriter][DumpProcess] : ## DUMP MODULES ##
23:37:40.46 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Planned scheduler executed...
23:37:45.468 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Executing planned scheduler...
23:37:45.468 Trace: [LogWriter][DumpProcess] : ## DUMP MODULES ##
23:37:45.468 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Planned scheduler executed...
23:37:50.474 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Executing planned scheduler...
23:37:50.475 Trace: [LogWriter][DumpProcess] : ## DUMP MODULES ##
23:37:50.476 Debug: [#=zsKD8eId5_o3AwBX85g==][MoveNext] : HRDLog update status not triggered. Check internet connection / HRDLog settings / CAT running status
23:37:50.477 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Planned scheduler executed...
23:37:55.495 Trace: [#=zzrkTtj8H$O4_Kbqckg==][MoveNext] : Executing planned scheduler...
23:37:55.496 Trace: [LogWriter][DumpProcess] : ## DUMP MODULES ##
Could it be internet access related? There are no obvious usage problems showing up on task manager on the PC.
Cannot make user configuration active - response delays?
Re: Cannot make user configuration active - response delays?
Do you have the same problem if you temporarily turn off your antivirus and firewall software?
