Suddenly I am unable to upload to LotW. I haven't changed anything except to upgrade Log4OM to 2.15.0.0. The program hangs after I "select required" then "upload". Other programs, i.e., GridTracker, seem to upload okay.
Thanks for any help you can provide.
Steve, W6SDM
Upload to LotW hangs
Re: Upload to LotW hangs
Steve,W6SDM wrote: 25 Jul 2021, 23:54 Suddenly I am unable to upload to LotW. I haven't changed anything except to upgrade Log4OM to 2.15.0.0. The program hangs after I "select required" then "upload". Other programs, i.e., GridTracker, seem to upload okay.
Steve, W6SDM
Many threads about this similar situation.
Update your TQSL and you should be good. The current version is: 2.5.8
Release Notes indicate changes made to the LOTW uploads at request of users and also due to changes made in LOTW. They have since had another release as I noted above.
Pls advise once you update TQSL and try again.
Thanks, Nolan. I upgraded to 2.5.8 and I am having the same result. In hangs after the message:
INFO: ADIF File created successfully.
INFO: TQSL Version 2.5.8
Executing TQSL with upload
Steve, W6SDM
Steve, W6SDM
Steve,W6SDM wrote: 26 Jul 2021, 02:39 Thanks, Nolan. I upgraded to 2.5.8 and I am having the same result. In hangs after the message:
Steve, W6SDM
Scan through this thread and be sure to also look at the link that Terry provided in one of the posts.
Might be able to uncover something there that will help.
https://forum.log4om.com/viewtopic.php?f=31&t=6837
No changes, Nolan. Even after updating TQSL and the latest update of LotW, the program still hangs when I upload. I can send an ADIF file to LotW.
Steve, W6SDM
Steve, W6SDM
EMAIL me a screenshot of your log4om program config LOTW setup screen - DO NOT POST IT ON THE FORUM
I am experiencing this same hang up. It seems to upload to LOTW ok on closing Log4OM but hangs if I try to upload manually. I have the latest TQSL and have studied the manual extensively but cannot get a solution. Any advice gratefully received.
