Hi All
I have been using Log40m for the last six months and am very pleased with no problems, and would like to move all my settings to a new pc, I have looked at the manual, and it says to move C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\user from one computer to the other, however I dont't have this file
Hands up not sure if I ran as administrator when I installed or on the new pc, not put any data on the new pc so could I reinstall as administrator?
Is there any way round the problem I have created, or do I need to set my configeration manually, I suppose it will teach me to read the manual.
Both windows 10 pcs running the latest versions of log40m.
Thanks Clive
Migrate to new pc
Re: Migrate to new pc
Google Show hidden files and folders
The Log4OM folder only exists after install
Hi Terry
Thanks for that, found the file, should I just overwrite the file contents on the new pc.
Also am I best doing a fresh install on the new pc and run as administrator.
thanks Clive
thanks Clive
Make sure that you make backups before overwriting anything so that you can recover if necessary
Now I am confused you talk of a fresh install but apparently its a new PC with Log4OM not installed so any install will be fresh!
If you are expecting to integrate other software like WSJT with Log4OM and Omnirig then all of the associated software should be run as an administrator otherwise the multithreading of Omnirig cannot be used.
Hi
Thanks almost up and running now, just the google map data is not showing up in the right box, only a large scale map, I have google maps and earth installed, do I need to allow the maps to be shared with Log40m.
Thanks clive
Thanks clive
Clive,
Maps are discussed in the current User Guide on Pages 43 - 49.
Hi
Thanks all up and running now.
Clive
Clive
