LOG4OMV2 integration with N1MM+ and JTDX
Posted: 27 Aug 2021, 16:43
Hello gurus.
I have managed to have all 3 programs work together simultaneously to a great satisfaction:
QSO data is saved in all 3 logs when I hit "LOG QSO" in JTDX, and deleting a QSO from N1MM+'s log deletes it as well in LOG4OM.
The only issue so far is that when I select a callsign to work - either from JTDX's "left screen" or from N1MM+'s "WSJT-X decode list screen" - it doesn't show in LOG4OM's callsign box (not passed\transmitted?).
(FWIW with JTDX, JTAlert & LOG4OM, all is just fine).
The setup is basically per the manuals:
N1MM+ broadcasts on 12060, LOG4OM has a UDP listener for N1MM+ message on 12060 as well, and JTDX reports to both UDP servers at 2237 & 2233 ports.
Any thoughts? I know I am probably missing something quite fundamental, but I am lost.
TIA, Isaac
TIA, Isaac
