Clicking on Cluster spots - no frequency selection
VK2MET
Post by VK2MET »
I must have done something to my setup - I was sure that when I clicked on a Cluster entry the QSO data was populated including the frequency and band. But now I notice they are not being populated and I have to manually enter the frequency and band.
The award refs etc are still going in.. so what have I done and how do I return it to the previous setting?
thanks
Alan
Re: Clicking on Cluster spots - no frequency selection
VK2MET wrote: 07 Sep 2021, 05:49 I must have done something to my setup - I was sure that when I clicked on a Cluster entry the QSO data was populated including the frequency and band. But now I notice they are not being populated and I have to manually enter the frequency and band.
thanks
Alan
Alan,
Check to make sure your CAT control is turned on and operating to your rig. Cluster clicks will not have frequency/band populate unless CAT is turned ON.
VK2MET
Post by VK2MET »
Thanks Nolan,
In fact it's the reverse. When CAT is ON but not connected, then the Cluster clicks do no populate.
I do not always have CAT ON but when I turn it OFF when the ports are not open, then the frequency/band are in deed populated.
thanks
Alan
