Since the last two versions I now receive a tqsl message on program close.
I have no idea what this message means and makes no sense to me.
Can you help with this?
Thanks, F5VJC
tqsl Message on program close
Re: tqsl Message on program close
Denis,F5VJC wrote: 13 Sep 2021, 19:21 Since the last two versions I now receive a tqsl message on program close.
Thanks, F5VJC
Are you using the LOTW Auto-Upload when Log4OM is closed?
Can you capture a screen-clip of the TQSL message?
Is it possibly the same or similar message that one gets when doing a 'manual' upload of LOTW from the QSL Manager routine?
Thanks, attached is the tqsl message I get when closing the prog.
I do have LOTW configured for Auto upload.
- tqsl message.PNG (31.17 KiB) Viewed 1269 times
Denis,
Just a thought. What version of TQSL are you using?
Be sure to use the most current.
V 2.5.8 and Configuration Data V 11.15 are the most recent.
